Ardumower Sunray
Version vom 7. März 2020, 19:09 Uhr von Alexanderg (Diskussion | Beiträge) (→‎XBee RF modules issues)
PCB Environment 'AG' (mostly open sky)
PCB Environment 'ML' (slightly limited sky view, higher nearby buildings and trees)
  • Optimized for Arduino Due
PCB     PCB
If you experience RTK float-to-fix recovery issues (no fix after timeout), the problem might be satellite reflections in the navigation solution: PCB
The solution to this problem is to configure a signal strength filter like below (to filter out satellite reflections): PCB
We are currently experimenting with different GPS antennas for the rover. The helical and survey antennas seem to perform slightly better than the normal patch antennas. A RTK-FIX solution is obtained more quickly and hold longer in challenging lawn environments with them.
Recording perimeter polygon and exclusions polygons
600px
