Ardumower Sunray
Version vom 7. März 2020, 19:13 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Bluetooth Low Energy (BLE) external antenna hack)
PCB Environment 'AG' (mostly open sky)
PCB Environment 'ML' (slightly limited sky view, higher nearby buildings and trees)
  • Optimized for Arduino Due
PCB     PCB
If you experience RTK float-to-fix recovery issues (no fix after timeout), the problem might be satellite reflections in the navigation solution: PCB
The solution to this problem is to configure a signal strength filter like below (to filter out satellite reflections): PCB
XBee RF modules issues
We are currently experimenting with different GPS antennas for the rover. The helical and survey antennas seem to perform slightly better than the normal patch antennas. A RTK-FIX solution is obtained more quickly and hold longer in challenging lawn environments with them.
IMU
You can add an IMU (MPU6050) like shown below to improve short-term direction measurements:
Recording perimeter polygon and exclusions polygons
600px
