Ardumower Sunray
Version vom 8. März 2020, 14:25 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Videos (Demos/Tutorials))
PCB Environment 'AG' (mostly open sky)
PCB Environment 'ML' (slightly limited sky view, higher nearby buildings and trees)
  • Optimized for Arduino Due
PCB     PCB
XBee RF modules issues
Optional: You can install an IMU (MPU6050) like shown below to improve short-term direction measurements (in addition to wheel odometry):
Recording perimeter polygon and exclusions polygons
600px
