Ardumower Sunray
PCB Environment 'AG' (mostly open sky)
PCB Environment 'ML' (slightly limited sky view, higher nearby buildings and trees)
  • Optimized for Arduino Due
4. Configure your preferred NTRIP service provider (Host, port, Mountpoint, Username, password), and through which WiFi network should it connect to internet. Example NTRIP mount points (Germany SAPOS service generating virtual reference station):
 Nordrhein Westfalen: VRS_3_4G_NW
 Berlin: VRS_3_2G_BE
PCB     PCB
In the App, you can choose between two position source modes:
relative: the rover coordinates are relative to the base antenna
absolute: the rover coordinates are computed as relative to some specified world coordinate (see image below)
XBee RF modules issues
Optional: You can install an IMU (MPU6050) like shown below to improve short-term direction measurements (in addition to wheel odometry):
Recording perimeter polygon and exclusions polygons
600px
