Ardumower Sunray
Version vom 12. März 2020, 01:20 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Videos (Demos/Tutorials))
PCB Environment 'AG' (mostly open sky)
PCB Environment 'ML' (slightly limited sky view, higher nearby buildings and trees)
  • Optimized for Arduino Due
4. Configure your preferred NTRIP service provider (Host, port, Mountpoint, Username, password), and through which WiFi network should it connect to internet. Example NTRIP mount points (Germany SAPOS service generating virtual reference station):
 Nordrhein Westfalen: VRS_3_4G_NW
 Berlin: VRS_3_2G_BE
8. If your NTRIP base antenna position is not constant, you have to switch to position source mode 'absolute' in the App (see section App for more details).
PCB     PCB
01-14 UBX-NAV-HPPOSLLH
relative: the rover coordinates are relative to the base antenna with coordinate (0,0)
absolute: the rover coordinates are computed as relative to some specified world coordinate (see image below)
XBee RF modules issues
Optional: You can install an IMU (MPU6050) like shown below to improve short-term direction measurements (in addition to wheel odometry):
Recording perimeter polygon and exclusions polygons
600px
