Ardumower Sunray
Version vom 26. März 2020, 02:30 Uhr von Alexanderg (Diskussion | Beiträge) (→‎How can I find out if my NTRIP provider (e.g. SAPOS) supports the required correction messages)
PCB Environment 'AG' (mostly open sky)
PCB Environment 'ML' (slightly limited sky view, higher nearby buildings and trees)
  • Optimized for Arduino Due
6. Connect the rover PCB via USB to your PC, and make sure NMEA protocol out is activated for UART2 out at 115'200bps (configuration view-> message 'PRT (Ports)'). Also make sure NMEA GGA message is active active on UART2 (configuration view->message 'MSG (Messages)'->F0-00 NMEA GxGGA). Some NTRIP service providers need this NMEA message to compute a virtual base station (VRS) based on the initial estimated GPS fix position.
8. If your NTRIP base antenna position is not constant, you have to switch to position source mode 'absolute' in the App (see section App for more details).
    1074: GPS MSM4
    1084: GLONASS MSM4
    1094: GALILEO MSM4
    1124: Beidou MSM4
    1230: GLONASS code-phase
PCB     PCB
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
XBee RF modules issues
Optional: You can install an IMU (MPU6050) like shown below to improve short-term direction measurements (in addition to wheel odometry). NOTE: IMU support has not been tested thoroughly (for a longer duration) yet.
Recording perimeter polygon and exclusions polygons
600px
How the path finding works
600px
600px
