Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 16 RTK float-to-fix recovery issues
- 17 XBee RF modules issues
- 18 GPS antenna selection guide
- 19 Bluetooth Low Energy (BLE) external antenna hack
- 20 IMU, sensor fusion
- 21 Recording perimeter polygon and exclusions polygons
- 25 Discussion / questions / forum thread
- Optimized for Arduino Due
Nordrhein Westfalen (SAPOS HEPS): VRS_3_4G_NW Niedersachsen (SAPOS HEPS): VRS_3_2G_NI Berlin (SAPOS HEPS): VRS_3_2G_BE
6. Connect the rover PCB via USB to your PC, and make sure NMEA protocol out is activated for UART2 out at 115'200bps (configuration view-> message 'PRT (Ports)'). Also make sure NMEA GGA message is active active on UART2 (configuration view->message 'MSG (Messages)'->F0-00 NMEA GxGGA). Some NTRIP service providers need this NMEA message to compute a virtual base station (VRS) based on the initial estimated GPS fix position.
8. If your NTRIP base antenna position is not constant, you have to switch to position source mode 'absolute' in the App (see section App for more details).
How can I find out if my NTRIP provider (e.g. SAPOS) supports the required correction messages
1074: GPS MSM4
1084: GLONASS MSM4
1094: GALILEO MSM4
1124: Beidou MSM4
1230: GLONASS code-phase
