Ardumower Sunray
Version vom 9. April 2020, 11:22 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Record perimeter and exclusions)
PCB Environment 'AG' (mostly open sky)
PCB Environment 'ML' (slightly limited sky view, higher nearby buildings and trees)
  • Optimized for Arduino Due
6. Save configuration and reset the system. From now on, every time the WiFi hotspot you configured is in range, the WiFi NTRIP Master will connect autonomously and provide RTK corrections to your rover PCB.
    1074: GPS MSM4
    1084: GLONASS MSM4
    1094: GALILEO MSM4
    1124: Beidou MSM4
    1230: GLONASS code-phase
PCB     PCB
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
Please watch this help video for recording perimeter and exclusions: Tutorial: How to use the app video (German with English subtitles)
Recording perimeter polygon and exclusions polygons
600px
How the path finding works
600px
600px
identical
  F0-00 F0-00 NMEA GxGGA
measurement period: 200ms (5 Hz)
baudrate UART1: 115200
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
