Ardumower Sunray
NOTE: This is software is still in EXPERIMENTAL state!
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 15 Odometry test
- 17 RTK float-to-fix recovery issues
- 21 IMU, sensor fusion
- 25 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 26 Discussion / questions / forum thread
- Optimized for Arduino Due
Default setting: Minimum number satellites required with 0 dbHz: 0 More restrictive setting: Minimum number satellites required with 30 dbHz: 10
This might be the right hack for you :-) This is how I added an external SMA antenna to the Bluetooth 4.0/BLE UART module (CC2540) to increase range. Happy hacking :-)
MSG (messages)
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
