Ardumower Sunray
NOTE: This is software is still in EXPERIMENTAL state!
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 15 Odometry test
- 17 RTK float-to-fix recovery and false-fix issues
- 21 IMU, sensor fusion
- 24 How the waypoints are generated
- 25 How the path finding works
- 26 How the obstacle avoidance works
- 27 What data is transferred to the Arduino
- 28 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 29 Discussion / questions / forum thread
- Optimized for Arduino Due
Tip: You can use u-center to monitor the signal strength etc. of all by the GPS receiver discovered satellites:
If you want to look for the signal strength of the sent frequencies (L1,L2 etc.), you can do this as well:
MSG (messages)
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
