Ardumower Sunray
Version vom 7. Juni 2020, 12:36 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Significant changes compared to Ardumower's initial firmware (Sunray vs. Azurit))
Icons experimental.png NOTE: This RTK mower project is still in EXPERIMENTAL state!
  • Optimized for Arduino Due
PCB     PCB
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
Tip: You can use Google Maps to find out (Lon, Lat) coordinates for your location: https://www.latlong.net/ PCB
For your first NTRIP tests (or even as permanent installation), you might use a portable 4G/WiFi router. Such 4G modem could be used where the WiFi coverage is limited. In addition, you can operate multiple WiFi devices (Ardumower PCB WiFi module, NTRIP client WiFi module, ESP32-CAM WiFi module etc.) via this portable 4G WiFi router.
Longer battery operation time
500px
500px
How the path finding works
600px
600px 400px
How the line tracking works
A Stanley controller is used to precisely track the lines between the waypoints:
600px
600px
MSG (messages):
  F5-05 RTCM3.3 1005
  F5-4A RTCM3.3 1074
  F5-54 RTCM3.3 1084
  F5-5E RTCM3.3 1094
  F5-7C RTCM3.3 1124
  F5-E6 RTCM3.3 1230
MSG (messages)
            baudrate UART2: 115200
            protocol out UART2: NMEA
            protocol in UART2: RTCM3
