Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Position source mode
- 16 Odometry test
- 17 RTK GPS test (invalid, float, fix) and FIX robustness and correctness
- 18 RTK float-to-fix recovery and false-fix issues
- 19 XBee RF bandwidth/corruption issues
- 20 GPS antenna selection guide
- 21 IMU, sensor fusion
- 24 WiFi module
- 25 Bluetooth Low Energy (BLE) and WiFi external antenna hacks
- 26 How the waypoints are generated
- 27 How the path finding works
- 28 How the obstacle avoidance works
- 29 How the line tracking works
- 30 What data is transferred to the Arduino
- 31 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 32 Discussion / questions / forum thread
- Optimized for Arduino Due
This section describes the 'rubber-band' path-finder algorithm that computes the path finding from one source point to some destination point considering obstacles (perimeter and exclusion polygons). Among other things, the path finding is used to compute:
- the path from one ring to another
- the path from current robot position to docking station and from docking station back to current mowing position
- the path around dynamic obstacles
Click here for path finder demonstration video
path-finder algorithm: left side shows new 'rubber-band' algorithm, right side some older algorithm (no longer used) 500px 500px
- the lateral error (distance from the planned (green) line - see yellow arrows below)
- the angular error (angle to the goal/target - see red arrows below)
MSG (messages)
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
