Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Position source mode
- 17 Odometry test
- 20 GPS checksum errors
- 23 IMU, sensor fusion
- 27 Docking
- 28 WiFi module
- Optimized for Arduino Due
If you experience ublox GPS receiver transmission checksum errors (shown in the Arduino serial monitor or in the App under Statistics)...
10:40:58.012 -> ublox chka error, msgclass=1, msgid=14, msglen=24: 5!=7F 10:41:58.036 -> ublox chka error, msgclass=1, msgid=14, msglen=24: 29!=C 10:42:58.019 -> ublox chka error, msgclass=1, msgid=14, msglen=24: 2A!=DC 10:43:58.033 -> ublox chka error, msgclass=1, msgid=14, msglen=24: 5!=FF 10:44:58.001 -> ublox chka error, msgclass=1, msgid=14, msglen=24: 8A!=44 10:45:58.023 -> ublox chkb error, msgclass=1, msgid=7, msglen=5C: B5!=27
MSG (messages)
baudrate UART2: 115200
protocol out UART2: NMEA
protocol in UART2: RTCM3
