Ardumower Sunray
Version vom 29. Juli 2020, 10:47 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Longer battery operation time)
  • Optimized for Arduino Due
01-12 UBX-NAV-VELNED
01-14 UBX-NAV-HPPOSLLH
If you experience ublox GPS receiver transmission checksum errors (shown in the Arduino serial monitor or in the App under Statistics)...
There are now two variants of the Ardumower battery pack (5Ah and 10Ah): https://www.asn-shop.de/Ardumower-Rasen-Roboter-Akku
MSG (messages):
  F5-05 RTCM3.3 1005
  F5-4A RTCM3.3 1074
  F5-54 RTCM3.3 1084
  F5-5E RTCM3.3 1094
  F5-7C RTCM3.3 1124
  F5-E6 RTCM3.3 1230
MSG (messages)                   solution frequency (10 means message is sent every 10 solutions)
  F0-00 NMEA-GxGGA               10
  01-07 UBX-NAV-PVT              10
  01-12 UBX-NAV-VELNED           1
  01-14 UBX-NAV-HPPOSLLH         1
  01-3C NAV-RELPOSNED            1
  02-32 RXM-RTCM                 1
            baudrate UART2: 115200
            protocol out UART2: NMEA
            protocol in UART2: RTCM3
GPS/RTK WiFi NTRIP and RTK non-stable fix issues: https://forum.ardumower.de/threads/frage-zum-gps-rtk-wifi-ntrip.23866/post-41712
XBee Long Range module, up to 14km, 13 dBm ERP (Xbee SX 868 xb8x-dmrs-001)
