Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Position source mode
- 17 Odometry test
- 20 GPS checksum errors
- 23 IMU, sensor fusion
- 27 Docking
- 28 WiFi module
- 32 Troubleshooting
- 33 Datasheets
- Optimized for Arduino Due
If you experience ublox GPS receiver-to-Arduino transmission checksum errors ('GPS checksum errors') shown in App under Statistics->GPS checksum errors:
PRT (ports) protocol UART2 in: RTCM3
protocol UART2 out: RTCM3
baudrate UART2: 115200 baud
MSG (messages) for UART2 transmit frequency (10 means message is sent every 10 solutions):
F5-05 RTCM3.3 1005 1
F5-4A RTCM3.3 1074 1
F5-54 RTCM3.3 1084 1
F5-5E RTCM3.3 1094 1
F5-7C RTCM3.3 1124 1
F5-E6 RTCM3.3 1230 1
MSG (messages) for UART1+USB transmit frequency (10 means message is sent every 10 solutions)
F0-00 NMEA-GxGGA 10
01-07 UBX-NAV-PVT 10
01-12 UBX-NAV-VELNED 1
01-14 UBX-NAV-HPPOSLLH 1
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 1
protocol out UART2: NMEA
protocol in UART2: RTCM3
Min SV elevation 10 10 (stefan config)
C/N0 Threshold #SVs 10 0 (stefan config)
dbHz 30 10 (stefan config)
- Does the 'GPS checksum error' shown in the App (Statistics) increase? If yes, check section above on how to increase Arduino serial FIFO size.
- Does the 'DGPS age' shown in the App increase too much (>5 seconds)? If yes, verify your WiFi or XBee connection (see section extending outdoor WiFi above on how to improve WiFi connection).
- Is the 'number of DGPS signals' show in the App (example: #37/77 means 37 DGPS signals versus 77 total signals) almost zero? If so, your base is not sending sufficient correction signals.
- ublox f9p firmware upgrade guide: https://www.ardusimple.com/zed-f9p-firmware-update-with-simplertk2b/
