Ardumower Sunray
Version vom 2. August 2020, 13:33 Uhr von Alexanderg (Diskussion | Beiträge) (→‎What are the differences between the Ardumower and ArduSimple ublox receiver configurations)
  • Optimized for Arduino Due
If you experience ublox GPS receiver-to-Arduino transmission checksum errors ('GPS checksum errors') shown in App under Statistics->GPS checksum errors:
Longer battery operation time
PRT (ports) protocol UART2 in:            RTCM3
            protocol UART2 out:           RTCM3
            baudrate UART2:               115200 baud
MSG (messages) for UART2                  transmit frequency (10 means message is sent every 10 solutions):
MSG (messages) for UART1+USB              transmit frequency (10 means message is sent every 10 solutions)
PRT (ports) baudrate UART1:               115200
            protocol out UART2:           NMEA
            protocol in UART2:            RTCM3
  Min SV elevation                        10                10 (hartmut config)
  C/N0 Threshold #SVs                     10                0  (hartmut config)
  dbHz                                    30                10 (hartmut config)
  • Does the 'GPS checksum error' shown in the App (Statistics) increase? If yes, check section above on how to increase Arduino serial FIFO size.
  • Does the 'DGPS age' shown in the App increase too much (>5 seconds)? If yes, verify your WiFi or XBee connection (see section extending outdoor WiFi above on how to improve WiFi connection).
