Ardumower Sunray
Version vom 2. August 2020, 14:38 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Method 1: Your own RTK base)
  • Optimized for Arduino Due
9. Choose 'View->Configuration View'. Choose configuration message 'TMOD3(Time mode 3)' and choose Mode '2 - Fixed Mode'. Enter your base coordinates as shown in the image and click on 'Send'. Your base should get a '3D fix' position solution.
If you experience ublox GPS receiver-to-Arduino transmission checksum errors ('GPS checksum errors') shown in App under Statistics->GPS checksum errors:
Longer battery operation time
  • Does the 'GPS checksum error' shown in the App (Statistics) increase? If yes, check section above on how to increase Arduino serial FIFO size.
  • Does the 'DGPS age' shown in the App increase too much (>5 seconds)? If yes, verify your WiFi or XBee connection (see section extending outdoor WiFi above on how to improve WiFi connection).
