Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Position source mode
- 17 Odometry test
- 20 GPS checksum errors
- 23 IMU, sensor fusion
- 27 Docking
- 28 WiFi module
- 32 Troubleshooting
- 33 Datasheets
- Optimized for Arduino Due
9. Choose 'View->Configuration View'. Choose configuration message 'TMOD3(Time mode 3)' and choose Mode '2 - Fixed Mode'. Enter your base coordinates as shown in the image and click on 'Send'. Your base should get a '3D' position solution.
- Change: #define SERIAL_BUFFER_SIZE 128 into into: #define SERIAL_BUFFER_SIZE 2048
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 10
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
Min SV elevation 10 OR 10 (hartmut config)
C/N0 Threshold #SVs 10 OR 0 (hartmut config)
dbHz 30 OR 10 (hartmut config)
- Does the robot position jump sporadically and does the 'GPS checksum error' shown in the App (Statistics) increase? If yes, check section above (GPS checksum error) on how to increase Arduino serial FIFO size.
- Does the 'DGPS age' shown in the App increase too much (>5 seconds)? If yes, verify your WiFi or XBee connection (see section extending outdoor WiFi above on how to improve WiFi connection). Also, verify the LEDs on the GPS modules - at the base, the LED 'GPS->XBEE' should blink and on the rover, the LED 'XBEE->GPS' should blink.
- ublox f9p firmware upgrade guide: https://www.ardusimple.com/zed-f9p-firmware-update-with-simplertk2b/
