Ardumower Sunray
Version vom 8. August 2020, 19:46 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Method 1: Your own RTK base)
  • Optimized for Arduino Due
  3. Change: #define SERIAL_BUFFER_SIZE 128 into into: #define SERIAL_BUFFER_SIZE 2048
We are currently experimenting with different GPS antennas for the rover. Best fix-solution results have been reported by using the Survey antenna.
Longer battery operation time
  • Does the robot position jump sporadically and does the 'GPS checksum error' shown in the App (Statistics) increase? If yes, check section above (GPS checksum error) on how to increase Arduino serial FIFO size.
  • Does the 'DGPS age' shown in the App increase too much (>5 seconds)? If yes, verify your WiFi or XBee connection (see section extending outdoor WiFi above on how to improve WiFi connection). Also, verify the LEDs on the GPS modules - at the base, the LED 'GPS->XBEE' should blink and on the rover, the LED 'XBEE->GPS' should blink. Also, verify that your base is configured for 'Fixed Mode' properly (see section 'RTK base / Your own RTK base' above).
