Ardumower Sunray
Version vom 9. August 2020, 09:45 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Record perimeter and exclusions)
  • Optimized for Arduino Due
  3. Change: #define SERIAL_BUFFER_SIZE 128 into into: #define SERIAL_BUFFER_SIZE 2048
We are currently experimenting with different GPS antennas for the rover. Best fix-solution results have been reported by using the Survey antenna.
Longer battery operation time
  • Does the robot position jump sporadically and does the 'GPS checksum error' shown in the App (Statistics) increase? If yes, check section above (GPS checksum error) on how to increase Arduino serial FIFO size.
