Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Position source mode
- 17 Odometry test
- 20 GPS checksum errors
- 23 IMU, sensor fusion
- 27 Docking
- 28 WiFi module
- 31 Troubleshooting
- 32 How to record GPS data
- 33 Datasheets
- 34 Discussion / questions / forum thread
- Optimized for Arduino Due
- Change: #define SERIAL_BUFFER_SIZE 128 into into: #define SERIAL_BUFFER_SIZE 2048
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 10
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
Min SV elevation 10 OR 10 (hartmut config)
C/N0 Threshold #SVs 10 OR 0 (hartmut config)
dbHz 30 OR 10 (hartmut config)
- Does the robot position jump sporadically and does the 'GPS checksum error' shown in the App (Statistics) increase? If yes, check section above (GPS checksum error) on how to increase Arduino serial FIFO size.
- ublox f9p firmware upgrade guide: https://www.ardusimple.com/zed-f9p-firmware-update-with-simplertk2b/
