Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 RTK base
- 10 RTK rover
- 13 Phone App
- 14 Odometry test
- 15 Position source mode
- 16 Record perimeter and exclusions
- 17 Mowing pattern, pattern angle, mowing offset
- 18 Odometry test
- 21 GPS checksum errors
- 24 IMU, sensor fusion
- 25 Extending WiFi range with outdoor access point
- 26 Portable WiFi router for NTRIP
- 27 Longer battery operation time
- 28 Docking
- 29 WiFi module
- 30 Bluetooth Low Energy (BLE) and WiFi external antenna hacks
- 31 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 32 Troubleshooting
- 33 How to record GPS data
- 34 Datasheets
- 35 Data privacy
- 36 Discussion / questions / forum thread
- Optimized for Arduino Due
- Change: #define SERIAL_BUFFER_SIZE 128 into into: #define SERIAL_BUFFER_SIZE 2048
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 10
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
Min SV elevation 10 OR 10 (hartmut config)
C/N0 Threshold #SVs 10 OR 0 (hartmut config)
dbHz 30 OR 10 (hartmut config)
- Does the robot position jump sporadically and does the 'GPS checksum error' shown in the App (Statistics) increase? If yes, check section above (GPS checksum error) on how to increase Arduino serial FIFO size.
- ublox f9p firmware upgrade guide: https://www.ardusimple.com/zed-f9p-firmware-update-with-simplertk2b/
