Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 Adafruit Grand Central M4
- 10 RTK base
- 11 RTK rover
- 14 Phone App
- 15 Odometry test
- 16 Position source mode
- 21 GPS checksum errors
- 24 IMU, sensor fusion
- 25 Ultrasonic sensor
- 29 Docking
- 30 WiFi module
- 33 Troubleshooting
- 34 How to record GPS data
- 35 Datasheets
- 36 Data privacy
- If using the Adafruit Grand Central M4 (highly recommended) instead of Arduino Due, you have to add 2.2K resistors (aka 'I2C pull-up') as shown below:
- Disable PCB1.3 jumper JP13 (deactivate Arduino Due clone reset circuit)
NOTE: It is recommended to upgrade the bootloader on the Adafruit Grand Central M4 board:
- Download the the latest bootloader file here (look for .UF2 bootloader file): https://circuitpython.org/board/grandcentral_m4_express/
- Copy the bootloader file to the Adafruit Grand Central M4 drive ('GCMBOOT') - the drive will disappear and after 10 seconds the drive will appear again. The bootloader upgrade has finished.
Alternative instructions here: https://learn.adafruit.com/adafruit-grand-central/update-the-uf2-bootloader
After upgrading the bootloader, follow the instructions here to add Adafruit Grand Central M4 support to the Arduino IDE: https://learn.adafruit.com/adafruit-grand-central/setup
6. Connect Arduino Due USB native port to your Computer's USB port. Upload the sketch to your Arduino Due on the Ardumower PCB1.3. After a short while you should hear a 'beep'. Ardumower is now ready for your commands!
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 10
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
Min SV elevation 10 OR 10 (hartmut config)
C/N0 Threshold #SVs 10 OR 0 (hartmut config)
dbHz 30 OR 10 (hartmut config)
