Ardumower Sunray
Version vom 1. September 2020, 19:40 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Adafruit Grand Central M4)
Using the new [https://www.marotronics.de/Adafruit-Grand-Central-M4-Express-featuring-the-SAMD51 Adafruit Grand Central M4 instead of Arduino Due is highly recommended as it has more memory for maps and a floating point for faster computations ...
  1. Add 2.2K resistors (aka 'I2C pull-up') to the Adafruit Grand Central M4 board as shown below.
  3. It is recommended to upgrade the bootloader on the Adafruit Grand Central M4 board. Download the the latest bootloader file here (look at the bottom of this link for .UF2 bootloader file): https://circuitpython.org/board/grandcentral_m4_express/
  7. Adding support for Adafruit Grand Central M4 to the Arduino IDE (so that the Grand Central M4 appears as board) is described further below (section 'Download, Arudino, Firmware').
4.2 For Adafruit Grand Central M4: Follow the instructions here to add Adafruit Grand Central M4 support to the Arduino IDE: https://learn.adafruit.com/adafruit-grand-central/setup
Longer battery operation time
