Ardumower Sunray
Version vom 10. September 2020, 10:44 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Discussion / questions / forum thread)
  3. It is recommended to upgrade the bootloader on the Adafruit Grand Central M4 board. Download the the latest bootloader file here (look at the bottom of this link for .UF2 bootloader file): https://circuitpython.org/board/grandcentral_m4_express/
  7. Follow the instructions here to add 'Adafruit Grand Central M4' support to the Arduino IDE by installing both Arduino SAMD boards and Adafruit SAMD boards packages : https://learn.adafruit.com/adafruit-grand-central/setup
Longer battery operation time
  Min SV elevation                        10          OR    10 (hartmut config)      10 (default)
  C/N0 Threshold #SVs                     10          OR    0  (hartmut config)      0
  dbHz                                    30          OR    10 (hartmut config)      0
For the very rare case that the Arduino hangs at a certain library, the watchdog in the Arduino has been programmed to reset the Arduino.
If this reset happens too often and you have the feeling it is a software issue, hardware-debugging might help.
In the Github folder 'openocd' you will find a readme.txt that describes how to connect a Raspberry PI to the Arduino for hardware-debugging. The idea is to set a 'breakpoint' at the watchdog interrupt for the case that the Arduino resets. The hardware-debugger (Raspberry PI in this case) can then be used to get a backtrace of the last function calls to locate the problem in the code.
[File: Sunray_hardware_debug.png|500px]
