Ardumower Sunray
Version vom 18. September 2020, 10:49 Uhr von Alexanderg (Diskussion | Beiträge) (→‎PCB1.3 GPS pin fix)
5. Remove any JP12 jumpers (please ignore the photo for this jumper - we will not use the level shifter, see section GPS pin fix further below)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
  • P5 GPS_RX is not working as expected - Fix it by removing jumper JP12 GPS_S and directly connecting P5 GPS_RX and Arduino TX3 using a wire as shown below.
  • IMPORTANT: On the rover GPS module, you also have to connect simpleRTK2B IOREF to simpleRTK2B 3V3_OUT (to choose signal voltage level 3.3v).
  3. It is highly recommended to upgrade the bootloader on the Adafruit Grand Central M4 board. Download the the latest bootloader file here (look at the bottom of this link for .UF2 bootloader file): https://circuitpython.org/board/grandcentral_m4_express/
  7. Follow the instructions here to add 'Adafruit Grand Central M4' support to the Arduino IDE by installing both Arduino SAMD boards and Adafruit SAMD boards packages : https://learn.adafruit.com/adafruit-grand-central/setup
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
