Ardumower Sunray
- 6 Bluetooth BLE UART module
- 7 PCB1.3 GPS pin fix
- 8 PCB1.3 odometry divider
- 9 Adafruit Grand Central M4
- 10 RTK base
- 11 RTK rover
- 14 Phone App
- 15 Odometry test
- 16 Position source mode
- 21 GPS checksum errors
- 24 IMU, sensor fusion
- 25 Ultrasonic sensor
- 29 Docking
- 30 WiFi module
- 33 Troubleshooting
- 34 How to record GPS data
- 35 Datasheets
- 36 Data privacy
- 38 SD card module
- 39 SD card logging
- 40 R/C model
- 41 Hardware debugging
5. Remove any JP12 (GPS signal) jumpers (please ignore the photo for this jumper - we will not use the level shifter, see section GPS pin fix further below)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA 60
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 60
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
C/N0 Threshold #SVs 10 0
dbHz 30 0
P13_1 +5V ----- R/C model VCC P13_2 GND ----- R/C model GND P13_3 pinRemoteMow ----- R/C model speed and direction channel (forward/backwards) P13_4 pinRemoteSteer ----- R/C model steering channel (left/right) P13_5 pinRemoteSpeed not used P13_6 pinRemoteSwitch not used
