Ardumower Sunray
Version vom 29. September 2020, 20:22 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Longer battery operation time)
5. Remove any JP12 (GPS signal) jumpers (please ignore the photo for this jumper - we will not use the level shifter, see section GPS pin fix further below)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA    60
Automatic battery switch off
You can set jumper JP8 to 'Automatic' to enable automatic battery switch off for a) undervoltage and b) if the robot is in idle mode. If you enable automatic battery switch off, it is recommended to add a 100 uF (63V) capacitor as shown below to be able to flash the Arduino without a sudden PCB switch off.
P13_1  +5V              ----- R/C model VCC
P13_2  GND              ----- R/C model GND
P13_3  pinRemoteMow     ----- R/C model speed and direction channel (forward/backwards)
P13_4  pinRemoteSteer   ----- R/C model steering channel (left/right)
