Ardumower Sunray
- 1 Key features
- 2 Videos (Demos/Tutorials)
- 3 What is RTK and what are the requirements (environment and hardware)
- 4 Assembling the chassis and PCB
- 5 Significant changes compared to Ardumower's initial firmware (Sunray vs. Azurit)
- 6 Installation steps
- 7 Bluetooth BLE UART module
- 8 PCB1.3 GPS pin fix
- 9 PCB1.3 odometry divider
- 11 RTK base
- 12 RTK rover
- 15 Phone App
- 16 Odometry test
- 17 Position source mode
- 22 GPS checksum errors
- 25 IMU, sensor fusion
- 26 Ultrasonic sensor
- 27 Extending WiFi range with outdoor access point
- 28 Portable WiFi router for NTRIP
- 29 Longer battery operation time
- 30 Automatic battery switch off
- 31 Docking
- 32 WiFi module
- 33 Bluetooth Low Energy (BLE) and WiFi external antenna hacks
- 34 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 35 Troubleshooting
- 36 How to record GPS data
- 37 Datasheets
- 38 Data privacy
- 39 Discussion / questions / forum thread
- 40 SD card module
- 41 SD card logging
- 42 R/C model
- 43 Hardware debugging
Key features
- Obstacle detection': ultrasonic, bumper and GPS
- Single mowing unit performance: 1 hour for 100 qm (4 days for 1 hectare)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA 60
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 60
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
C/N0 Threshold #SVs 10 0
dbHz 30 0
