Ardumower Sunray
Version vom 15. Oktober 2020, 09:55 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Method 2: Using an RTK external base service (Internet-based))
  • Single mowing unit ground coverage performance (0.4m/s, 18cm path offset) : 100 qm per hour / 2400 qm (=0.24 hectare) per day
  • Overall power consumption (average) with single mowing unit: 30W (60W peak)
  • Single battery (125Wh) run-time (average): 4 hours / double-battery (250Wh): 8 hours
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
Your own RTK base should be located max. 8 km away from your mowing area. The GPS antenna should have a clear sky view and is ideally mounted at a high position. Using long-range (LR) wireless RF modules, the GPS correction signal is transmitted to the robot (it's a one way transmission).
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
Automatic battery switch off
