Ardumower Sunray
Version vom 15. Oktober 2020, 10:08 Uhr von Alexanderg (Diskussion | Beiträge) (→‎RTK float-to-fix recovery and false-fix issues)
  • Single mowing unit ground coverage performance (0.4m/s, 18cm path offset) : 100 qm per hour / 2400 qm (=0.24 hectare) per day
  • Overall power consumption (average) with single mowing unit: 30W (60W peak)
  • Single battery (125Wh) run-time (average): 4 hours / double-battery (250Wh): 8 hours
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
Automatic battery switch off
