AzuritBer Firmware (English)
Version vom 27. Oktober 2020, 20:20 Uhr von Bernard (Diskussion | Beiträge) (→‎Odometry Setting)
What is AzuritBer and Why
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
It's level 2 but now:
First start Level 1
are correctly set.
Odometry Setting
Medium:D:\Bernard\ardumower image\Menu Ardumower\Main\Setting\Odometry\Odo_setting.jpg
Motor Setting
