AzuritBer Firmware (English)
Version vom 28. Oktober 2020, 13:50 Uhr von Bernard (Diskussion | Beiträge) (→‎Odometry Setting)
What is AzuritBer and Why
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
It's level 2 but now:
First start Level 1
are set like that.
Odometry Setting
3 Values are require Value 1 Go To : Main Menu / Setting / Odometry
200px
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
Motor Setting
