AzuritBer Firmware (English)
What is AzuritBer and Why
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
It's level 2 but now:
First start Level 1
are set like that.
Go To : Main Menu / Setting / Mow Motor
Set Force mowing off to YES
Odometry Setting
Value 1
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
Value 2
Value 3
Mower need to rotate according your choice.
Motor Setting
See PID Control : [1]
So to find the correct value ,simply deactivate bumper and In Manual / Forward stop the mower with your foot and normaly the mower stop before the wheel slip. State change to OFF and into console you can see the according message. Do not forget to reactivate the Bumper.
