AzuritBer Firmware (English)
Version vom 30. Oktober 2020, 17:59 Uhr von Bernard (Diskussion | Beiträge) (→‎First start Level 1)
What is AzuritBer and Why
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
It's level 2 but now:
First start Level 1
If you want to use IMU ,Be careful to choose the correct firmware (GY-88,GY-87 and MPU-9250 are possible)
are set like that to receive Console message inside the arduino ide console
****** SAFETY ******  Go To : Main Menu / Setting / Mow Motor
Set Force mowing off to YES
Odometry Setting
Value 1
200px
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
Value 2
Value 3
Mower need to rotate according your choice.
Motor Setting
See PID Control : [1]
So to find the correct value ,simply deactivate bumper and In Manual / Forward stop the mower with your foot and normaly the mower stop before the wheel slip. State change to OFF and into console you can see the according message. Do not forget to reactivate the Bumper.
Mow setting
Station setting
Perimeter setting
IMU setting
