AzuritBer Firmware (English)
What is AzuritBer and Why
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
It's level 2 but now:
First start Level 1
Normally if all is OK you have access to arduremote.
****** SAFETY ****** Go To : Main Menu / Setting / Mow Motor
Set Force mowing off to YES
Odometry Setting
Value 1
200px
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
Value 2
Value 3
Motor Setting
See PID Control : [1]
Mow setting
200px
Station setting
Perimeter setting
IMU setting
