AzuritBer Firmware (English)
What is AzuritBer and Why
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
It's level 2 but now:
First start Level 1
Set Force mowing off to YES
Odometry Setting
Value 1
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
Value 2
Value 3
Motor Setting
See PID Control : [1]
Mow setting
Set the PWM Max speed to 255
Set the PWM Min speed to 150
Station setting
Perimeter setting
IMU setting
The Compass use magnetic earth field and is disturb by all motor and electronics in the mower, so it's very difficult to have correct value (for example a change of 10 deg is possible if you move the mower for only 1 deg). But it's reliable (If indicate 25 Deg and roll for 360 deg or wait 10 minutes it's always 25 Deg)
The Gyro/Accel if very accurate (+/- 1 or 2 deg) but can drift over time, (If indicate 25Deg and you wait 5 minute it can be 30Deg, but when you rotate slowly the mower you can see that everything is OK from 0 to 179 and from -179 to 0 Deg)
If GY88/GY87 IMU is use ,you need to calibrate the GYRO/ACCEL on the initial instalation: Simply Go To Setting / IMU, press the ACCEL/GYRO initial calibration and wait 1 or 2 minutes without moving the mower. For MPU/9255 or 9250 this process is automaticly done on each start of the mower,so you can't see the button in arduremote .
Without Compass
To check if it's OK:
Go To : Main Menu / Test IMU
If GY88/GY87 IMU is use ,you need to calibrate it by simply press the
With Compass
