AzuritBer Firmware (English)
Version vom 31. Oktober 2020, 18:34 Uhr von Bernard (Diskussion | Beiträge) (→‎Perimeter setting)
What is AzuritBer and Why
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
It's level 2 but now:
First start Level 1
CONSOLE SHOW :
Set Force mowing off to YES
Odometry Setting
Value 1
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
CONSOLE SHOW:
Value 2
Value 3
Motor Setting
See PID Control : [1]
Mow setting
Set the PWM Max speed to 255
Set the PWM Min speed to 150
Station setting
Perimeter setting
Mini Smag:
Timeout(s) if outside :
Big AREA Smag Center
Tracking Max Speed PWM
Circle Arc Distance...
Perimeter MAG MAX VALUE
Transition Timeout
Track Error Timeout
Track PID
Coil Polarity
Read the 2 coils
Block inner wheel
IMU setting
Gyro/Accel if very accurate (+/- 1 or 2 deg) but can drift over time, (If indicate 25Deg and you wait 5 minute it can be 30Deg, but when you rotate slowly the mower you can see that everything is OK from 0 to 179 and from -179 to 0 Deg)
If GY88/GY87 IMU is use ,you need to calibrate the GYRO/ACCEL on the initial instalation: Simply Go To Setting / IMU, press the ACCEL/GYRO initial calibration and wait 1 or 2 minutes without moving the mower. For MPU/9255 or 9250 this process is automaticly done on each start of the mower,so you can't see the button in arduremote .
Without Compass
To check if it's OK:
Go To : Main Menu / Test IMU
With Compass
CONSOLE SHOW :
