AzuritBer Firmware (English)
What is AzuritBer and Why
Level 1 Standard
Level 2 Raspberry
It's Level 1 but now:
It's level 2 but now:
First start Level 1
CONSOLE SHOW :
Set Force mowing off to YES
ODOMETRY Setting
Value 1
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
CONSOLE SHOW:
Value 2
Value 3
MOTOR Setting
See PID Control : [1]
MOW setting
Set the PWM Max speed to 255
Set the PWM Min speed to 150
STATION setting
PERIMETER setting
Mini Smag:
Timeout(s) if outside :
Big AREA Smag Center
Tracking Max Speed PWM
Circle Arc Distance...
Perimeter MAG MAX VALUE
Transition Timeout
Track Error Timeout
Track PID
Coil Polarity
Read the 2 coils
Block inner wheel
IMU setting
IMU Use
Compass Use
Stop Mow Motor During Calib
P I D
Calibration Max Duration
Delay between 2 calib
'Drift Maxi in Deg per Second
Speed to find ComYaw
Without Compass
To check if it's OK:
Go To : Main Menu / Test IMU
With Compass
CONSOLE SHOW :
TIMER setting
BYLANE setting
3 mains Lane are set ,Factory are 45, 90 and 135 degrees (Avoid value near 0). For each Lane 2 opposites reverse heading are possible according the ROLL dir at the end of the initial lane.
Setting are made in live mode changing the Yaw Opposite and leave the Fixed Yaw to according value and see the result.
For example if for the lane 1 you set a fixed yaw to 45 deg, you can set Yaw opposite 1 Roll Left to -135 and Yaw opposite 1 Roll Right to -135, In this case the mower mow perfect parallel lane (reverse heading is exactly the opposite of fixed one)
Other example if for the lane 1 you set a fixed yaw to 45 deg, you can set Yaw opposite 1 Roll Left to -120 and Yaw opposite 1 Roll Right to -150, the mower mow in a kind of Zig Zag and go fast from one side of area to the other
Set the Dist Between lane according the weight of the mower.(In the example it's Robomow platform with 53cm cutting weight)
Lane Max length help to reduce the error on IMU heading (Reduce length to be sure the mower mow perfectly parallel)
BATTERY setting
Charge Factor
Battery Factor
Sense Factor
Go Home if Volt below
Switch off after minutes
Switch off if Volt below
Start charge if Voltage below
Stop charge if Sense below
SONAR setting
Sonar brake below
Only this distance is checked by the sonar.
Sonar To Front Dist
RAIN TEMP setting
Rain Use
DHT22Use
Maximum Temperature
When DHT22 temp is upper this value the mower goes into ERROR and the PCB is totally power OFF.
Level 2 Raspberry Pi
