WIFI Perimeter Sender(English)
WIFI Perimeter sender.
Hardware connecting
You need :
ESP32 DEV KIT V1 (or later but with same pin diagram).
ESP32 DEV KIT replace the bluetooth module HC05 to communicate with PCB1.3, so you can build a small PCB to connect all wire, or order some of them from JLCPCB for example (The same board is also use to build the WIFI sender.)
