Ardumower Sunray
Version vom 14. April 2021, 15:16 Uhr von BenPan (Diskussion | Beiträge) (→‎Bluetooth BLE UART module: Added link to Module-Error-List)
NOTE: If your experience Bluetooth module communication issues, have a look at the GPS RX pin fix and perform the same RX pin fix for the Bluetooth RX pin. You can find a list of working combinations of BLE-module and smartphone on this page: BLE-Module_-_List_of_variants.
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
volt=24
...some time later...
...many time later...
Automatic battery switch off
Flashing WiFi module
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
