Ardumower Sunray
Version vom 25. April 2021, 22:36 Uhr von Alexanderg (Diskussion | Beiträge) (→‎RTK GPS test (invalid, float, fix) and FIX robustness and correctness)
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
F0-00 F0-00 NMEA GxGGA    60
GPS status in the App: Sunray gps rtk fix.png
Longer battery operation time
volt=24
...some time later...
...many time later...
Automatic battery switch off
Flashing WiFi module
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
