Ardumower Sunray
Version vom 1. Mai 2021, 19:50 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Bluetooth BLE UART module)
1. Install ESP32 BLE+WiFi (recommended) or Bluetooth 4.0/BLE module (range 10m, 8 Kbps) on your Ardumower PCB1.3 (replace any installed Bluetooth 2.0 module).
4. Set JP7 (GpsV - GPS voltage) to 5V
5. IMPORTANT! Remove JP12 (GpsS - GPS signal level) jumpers (please IGNORE the photo for this jumper! - we will not use the level shifter, see section GPS pin fix further below)
If you have BLE firmware 5.3, the module may not work correctly or stable and it is recommended to use an ESP32 as a BLE+WiFi module:
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
  2. Remove jumper Gps_S (JP12)
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
volt=24
...some time later...
...many time later...
Automatic battery switch off
Flashing WiFi module
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
