Ardumower Sunray
Version vom 1. Mai 2021, 21:32 Uhr von Alexanderg (Diskussion | Beiträge) (→‎Bluetooth BLE/WiFi UART module (ESP32))
Due to the many issues with latest firmwares (on both BLE HM-10 modules and ESP8266), we decided to replace both BLE and WiFi modules by a single new module (ESP32). It works by removing any existing BLE and WiFi module and connecting the ESP32 to the PCB1.3 Bluetooth connector as shown below.
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
  2. Remove jumper Gps_S (JP12)
F0-00 F0-00 NMEA GxGGA    60
Longer battery operation time
volt=24
...some time later...
...many time later...
Automatic battery switch off
Do the same for messages:
01-43 NAV-SIG
0A-36 MON-COMMS
  • South America: 433 MHz
  • Africa: 433 MHz
  • Asia: 415/433 MHz
  • New Zealand: 917-927MHz
