Ardumower Sunray
- 8 PCB1.3 GPS pin fix
- 9 PCB1.3 odometry divider
- 11 RTK base
- 12 RTK rover
- 15 Phone App
- 16 Odometry test
- 17 Position source mode
- 22 GPS checksum errors
- 25 IMU, sensor fusion
- 26 Ultrasonic sensor
- 27 Extending WiFi range with outdoor access point
- 28 Portable WiFi router for NTRIP
- 29 Longer battery operation time
- 30 Automatic battery switch off
- 31 Docking
- 32 WiFi module
- 33 Bluetooth Low Energy (BLE) and WiFi external antenna
- 34 What are the differences between the Ardumower and ArduSimple ublox receiver configurations
- 35 Troubleshooting
- 36 How to record GPS data
- 37 Datasheets
- 38 Data privacy
- 39 Discussion / questions / forum thread
- 40 SD card module
- 41 SD card logging
- 42 R/C model
- 43 Hardware debugging
- 44 Firmware Console Debugging
- 45 Further links
Due to the many issues with latest firmwares (on both BLE HM-10 modules and ESP8266), we decided to replace both BLE and WiFi modules by a single new module (ESP32). It works by removing any existing BLE and WiFi module and connecting the ESP32 to the PCB1.3 Bluetooth connector as shown below.
Step 1: Swapping pins
Step 2: Fixing GPS_RX pin
- Remove jumper Gps_S (JP12)
F0-00 F0-00 NMEA GxGGA 60
F5-4A RTCM3.3 1074 GPS MSM4 1
F0-00 NMEA-GxGGA 60
01-3C UBX-NAV-RELPOSNED 1
01-43 UBX-NAV-SIG 10
02-32 RXM-RTCM 5
C/N0 Threshold #SVs 10 0
dbHz 30 0
Here you can find allowed LoRa (long-range) frequencies for each country as well as datasheets for the XBee and ublox modules. Europe: XBee Long Range module, 868 MHz, up to 14km, 13 dBm ERP/20mW, max. 80 Kbps (Xbee SX 868 xb8x-dmrs-001)
- South America: 433 MHz
- Africa: 433 MHz
- Asia: 415/433 MHz
- New Zealand: 917-927MHz
