Arduino first steps
Version vom 24. November 2014, 15:35 Uhr von Alexanderg (Diskussion | Beiträge)
If you have never worked with Arduino before, this page describes how to start with your Arduino that you can purchase via the shop .
All you need to run the example below is:
- One USB cable
2. Download
Click here to download the Arduino development software (v1.5.8) to your computer (Windows users should download the 'Installer' version on that page):
3. Install
After the download completed, install the Arduino development software on your computer: For Windows users, double click the downloaded file ('arduino-1.5.8-windows.exe') in your Windows file explorer to run the installation.
4. Run
5. Choose blink example
6. Choose correct board type
8. Upload the blink example
Click on the 'Upload' symbol to upload the blink example to your Arduino.
After the code is uploaded, your Arduino will start to blink!
Congratulations!
Now let's look a little bit closer at the above blink code to understand it:
The Arduino has several pins, each of them has a number. As you can see, Pin 13 is already connected to the on-board LED:
Each pin can be configured as either INPUT or OUTPUT depending on wheter you want to measure or control that pin :
OUTPUT means that you can write (or control) the voltage of that pin.
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
delay(1000);
So let's look at the complete blink program again:
void setup(){ pinMode(13, OUTPUT); // we want to control pin 13 } void loop(){ digitalWrite(13, HIGH); // pin 13 will go HIGH (voltage ON) delay(1000); // wait one second (=1000 milliseconds) digitalWrite(13, LOW); // pin 13 wil go LOW (voltage OFF) delay(1000); // wait one second (=1000 milliseconds) // ...now everything repeats }
How to go further...
