AzuritBer Pi Explain (English)
Piardu Help
Main Menu
All other icons are explicit.
Auto Page
It's the initial start menu.
Manual page
Setting Page
Main setting
Simple Setting
DUE Firmware Update
ByLane Setting
Console Page
Test Page
Plot Page
Timer Page
Video Page
GPS Page
RFID Page
Description is here :
