DIY Brushless Driver Board
Brushless Drive [2]
Brushless Adapter [3]
Blade-Motor Protection [4]
Description
Brushless Drive Test Software
- define Reg00
- define Reg0B
Connector Pinout
HAL Sensor:
clamp + : 5V Power out for HAL sensoric (ACT Motor HAL cable : red )
clamp W : HAL sensor W (ACT Motor HAL thin cable : blue )
Motor Coils:
clamp U : coil U (ACT Motor coil thick cable : yellow )
clamp V : coil V (ACT Motor coil thick cable : green )
clamp W : coil W (ACT Motor coil thick cable : blue )
Step 1 Soldering :
Step 2 Connect the Brushless Motor :
Step 3 Connect the Power :
If you have the BL Driver Version 1.1:
Bridge the EN signal (pin2) with +5V / VCC from the Nano.
If you habe the BL Driver Version 1.0:
Bridge the EN signal (pin2) and GND (pin 7) on the 8 pin flat cable connector.
Then plug in the Nano SPI plug into the SPI Board connector.
3D-printed PCB holder
Bug fix
Motor / Gearbox:
If you remove the gearbox from the motor please take care that no small parts are falling in the gearbox.
Specially take care about chunks from the screw protection lacquer. This will hinder the motor.
Brushless Adapter Version:
Link:
BL Odometry Signal:
Stock all contacts at the power side and do NOT add coolers to 7805 power IC
