Motor driver
Voltages
Protector PCB
Wheel motors wiring
  • steer the robot left/right
Wheel motor features:
  • 24V (load current ~1A)
Motor wiring (left motor):
Wheel motors odometry wiring
Motor (brown)  ---- PCB VCC
Motor (green)  ---- PCB GND
Mower motor wiring
Motor decrease noise
Motor controller (PID)
