AzuritBer Firmware (English)
Version vom 3. Februar 2022, 20:16 Uhr von Bernard (Diskussion | Beiträge) (→‎Level 2 WIFI and MQTT)
GITHUB Location
It's here:
GITHUB REPOSITORY
What is AzuritBer and Why
https://youtu.be/Abt5pcWz2H0
https://youtu.be/T5mH4yMyWus
WIFI ESP32 Sender
if you have only one mowing area , you can use sender from shop : sender start when mower leave station and stop when mower is back or after a 5 hours timeout.
The new sender is describe here:
Level 3 WIFI/RFID/MQTT
It's the standard PCB1.3 or 1.4 but the BT module is ESP32 one and a PN5180 RFID reader is connected to the ESP32
Using arduino IDE , You can download firmware inside ESP32 to have everything working : https://github.com/Boilevin/AzuritBer/tree/master/ESP32_RFID
Level 4 Raspberry
It's Level 1 but now:
Level 5 Raspberry + Rfid reader
Level 1 Standard
Hardware is standard one : the PCB1.3 or 1.4 and simple BT module HC05
Install Firmware in DUE
are set like that : uncomment #define Console Serial to receive Console message inside your PC arduino ide console and comment #define Console SerialUSB
Arduremote or PFOD APP
Main
Command
Arduremote
Possible value are :
Button connected on P20
If mower is in OFF state:
If mower is running:
Push it to stop immediately
Console
Setting
Here the setting page.
Set Force mowing off to YES
ODOMETRY Setting
Value 1
Go To : Main Menu / Test ODO
Use 1 turn Wheel FWD
CONSOLE SHOW:
Value 2
Value 3
MOTOR Setting
See PID Control : [1]
MOW setting
Set the PWM Max speed to 255
Set the PWM Min speed to 150
STATION setting
PERIMETER setting
Mini Smag:
Timeout(s) if outside :
Big AREA Smag Center
Tracking Max Speed PWM
Circle Arc Distance...
Perimeter MAG MAX VALUE
Transition Timeout
Track Error Timeout
Track PID
Coil Polarity
Read the 2 coils
Block inner wheel
Reduce Speed Near Wire
Actual Speed Coeff
IMU Wiring and Setting
MPU-9250 IMU WIRING TO PCB1.3
 IMU       PCB
 VCC <---> 3.3V
 GND <---> GND
 SDA <---> SDA
 SCL <---> SCL
 ADO <-> IMU VCC
GY-88 IMU WIRING TO PCB1.3
 IMU       PCB
 VCC <---> 3.3V
 GND <---> GND
 SDA <---> SDA
 SCL <---> SCL
 G_ADO <-> IMU VCC
IMU       PCB
 VCC <---> 3.3V
 GND <---> GND
 SDA <---> SDA
 SCL <---> SCL
 ADO <-> IMU VCC
IMU       PCB
 VCC <---> 3.3V
 GND <---> GND
 SDA <---> SDA
 SCL <---> SCL
GY-87 WIRING TO PCB1.3
 IMU       PCB
 VCC_IN <---> 3.3V
 GND <---> GND
 SDA <---> SDA
 SCL <---> SCL
IMU Main Setting
IMU Use
Stop Mow Motor During Calib
P I D
Calibration Max Duration
Delay between 2 calib
'Drift Maxi in Deg per Second
Speed to find ComYaw
SETTING Without Compass
To check if it's OK:
Go To : Main Menu / Test IMU
SETTING With Compass
CONSOLE SHOW :
TIMER setting
BYLANE setting
BATTERY setting
Charge Factor
Battery Factor
Sense Factor
Go Home if Volt below
Switch off after minutes
Switch off if Volt below
Start charge if Voltage below
Stop charge if Sense below
SONAR setting
Sonar brake below
Sonar To Front Dist
RAIN TEMP setting
Rain Use
DHT22Use
Maximum Temperature
OLED Screen setting
#define Enable_Screen true
In OFF mode :
While mower running :
When Charging :
Level 2 ADDING WIFI and MQTT
Description
This level require that you have WIFI on your mowing area using for example a outdoor WIFI repeater on your roof.
Bluetooth is limited to only 10/20 meter in free view, but with this option you can use PFOD APP over WIFI inside your house and control mower at long distance. You can also control the mower using Home Automation from your browser, but need a Mosquito broker running on a machine in you lan.
Hardware is the PCB1.3 / 1.4 but the standard HC05 BT module is replace by an ESP32 DEV KIT V1 .
A special firmware is upload inside the ESP32 to manage WIFI connection to PFOD and the MQTT protocol for use with home automation.
Wiring diagram:
Firmware Upload
You can use Arduino IDE to upload firmware in the ESP32
Code is locate into github: https://github.com/Boilevin/AzuritBer/tree/master/ESP32_RFID_mqtt
Now into config.h you need to adjust some line according your need.Everything is explain in the code ,so simply read and adjust according your config.
If your home WIFI is OK on the garden you can use your home SSID and password value.
If the mower don't have access to your home WIFI ,you need to configure ESP32 as access point and connect your phone to it
ssid     = "your acces point ssid";   // put here your acces point ssid
password = "password";  // put here the password
You need to use Arduino IDE to upload code into ESP32, It's easy and exactly same process that for Arduino DUE or Mega ,but need to select the correct board.
Add the ESP32 board to your arduino IDE: for more info see : https://randomnerdtutorials.com/installing-the-esp32-board-in-arduino-ide-windows-instructions/#:~:text=%20To%20install%20the%20ESP32%20board%20in%20your,button%20for%20the%20%E2%80%9C%20ESP32%20by...%20More%20
Open your Arduino Ide 1.8 or later
Select ESP32 DEV Module and correct COM port
To upload code do not forget : At the end of compilation when you see "connecting ....." --> push the BOOT button locate on ESP32 DEV KIT for 5 sec until start uploading
Level 2 Raspberry Pi
Level 3 Raspberry Pi + RFID
